Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
For a background on MSI the company says it best here:
Stealth represents just one of a dozen different product lines that MSI offers to the public. Hosted within the gaming laptop subcategory the Stealth Thin is an older model designed around the idea of gaming on the go. The Stealth Thin utilizes smaller bezels, a thinner case profile, and long lasting battery to provide a slim gaming package. Each laptop in the Stealth Thin series is customizable in areas like Computer Processing Unit, Random Access Memory, and Data Storage capabilities.
The stealth thin line up was the 1st thin gaming laptop for MSI that feature the NVIDIA GeForce GTX 1660 Ti graphics card and the 9th Generation Intel i7 processors. The screen offers a gaming-centric design at 15.6", top resolution of 1,920 x 1,080 (HD), and a 144 hertz refresh rate. While being thin the GS65 provides plenty of ports along the left and right sides of the laptop. On the left side the user can find an Ethernet port, two USB-C USB 3.0 ports, as well as the headphone/microphone jack. The right side there is the charging port, an HDMI port, Mini DisplayPort, a USB-C port with Thunderbolt 3, and one USB-A USB 3.0 port.
There are no current recall notices for the GS65 Stealth Thin model line. Some online users comment on the durability of the case material, noting that the laptops cannot be treated roughly otherwise plastic cracking and screen damage is possible. MSI offers a 12 month warranty on their gaming laptop product line on all hardware starting from the purchase. Users must register their laptop online with MSI to utilize the warranty services.
Sources:
MSI GS65 Stealth Thin Homepage
MSI GS65 Stealth Thin Specifications
MSI GS65 Stealth Thin PCMag Review
MSI GS65 STealth Thin CNET Review
Identification
To identify the MSI GS65 Stealth Thin 8RE laptop the owner can verify in two different ways. The first way involves only a physical inspection of the bottom of the laptop. All MSI products place their identification stickers on the bottom of the laptop (generally in the bottom right quadrant). The owner should not only see the product model number but also their individual serial number. Some laptops also include information like the MAC address. This sticker should allow a visual confirmation of the device, but in the event it is damaged or missing the second option is necessary.
If the owner cannot find the sticker on the outside of the device they can verify this information though the windows interface. Upon logging into their device the own can open the windows Start button, following by the Settings interface. From the Settings window home page the owner opens up the systems option (usually the top right option). Once they have entered the system window they can scroll to the bottom of the right hand menu and select the About option. The About page contains a lot of information including the Device ID, Product ID, and Serial Number.
Technical Specifications
Input/Output (I/O) Ports
  • 1x Type-C (USB3.1 Gen2 / DP / Thunderbolt™3)
  • 1x Type-C (USB3.2 Gen2 / DP / Thunderbolt™3)
  • 3x Type-A USB3.1
  • 1x HDMI™ 2.1 (4K @ 60Hz) HDMI™
  • 1x Mini-DisplayPort
  • 1x RJ45
Central Processing Unit (CPU)
  • Up to 8th Gen. Intel® Core™ i7 Processor
Operating System (OS)
  • Windows 10 Pro
  • Windows 10 Home
Chipset
  • Intel® HM370
AC Adapter
  • 180W Slim adapter
Battery
  • 4-cell
  • 82
Graphics
  • GeForce® GTX 1060 with 6GB GDDR5
Memory
  • Max 32GB
  • DDR4-2400
  • DDR4-2666
  • 2 Slots
Storage Capability
  • 1x M.2 SSD slot (NVMe PCIe Gen3)
  • 1x M.2 SSD Combo slot (NVMe PCIe Gen3 / SATA)
Webcam
  • HD type (30fps@720p)
Audio
  • 2x 2W Speaker
Keyboard
  • Per-Key RGB Keyboard
Communication
  • Killer Gb LAN
  • 802.11 ac Wi-Fi + Bluetooth v5
Audio Jack
  • 1x Mic-in
  • 1x Headphone-out (HiFi)
Dimension (WxDxH)
  • 357.7 x 247.7 x 17.9 mm
Weight (with Battery)
  • 1.88 kg
Additional Information
MSI GS65 Stealth Thin Drivers & Downloads
MSI GS65 Stealth Thin Manual & Document
MSI GS65 Stealth Thin FAQ
MSI GS65 Stealth Thin Warranty Information
Author
with
Matt Zieminski
50,484 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 101
All Time: 3,279
