MSI GS65 Stealth Thin 8RE RAM Replacement
    1. MSI GS65 Stealth Thin 8RE RAM Replacement, RAM: step 1, image 1 of 2 MSI GS65 Stealth Thin 8RE RAM Replacement, RAM: step 1, image 2 of 2
      • Remove the fifteen black 6.0 mm Phillips #00 screws from the back cover.
      • Carefully remove the back cover.
      • It may be easier to remove the back cover by starting at the ethernet port and running something thin along the sides until the panel pops off.
      • When reassembling the back cover, it should "click" into place.
      Ask FixBot
    2. MSI GS65 Stealth Thin 8RE RAM Replacement: step 2, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 2, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 2, image 3 of 3
      • Remove the three silver 4.0 mm Phillips #00 battery screws.
      • Separate the red wire running on top of the battery from the battery.
      • Lift the battery out slightly, then carefully wiggle and pull the battery connector cable out.
      • Be sure not to pull excessively on the battery when it is still connected to the motherboard.
      Ask FixBot
    3. MSI GS65 Stealth Thin 8RE RAM Replacement: step 3, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 3, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 3, image 3 of 3
      • Gently unclasp and unplug the four connectors by first lifting the black locking bars of the ZIF connectors.
      • The black locking tables can be lifted by using something small such as a fingernail.
      • There may be black tape covering the ribbon cables that need to be removed.
      • Be gentle while dealing with ribbon connectors since if damaged will cause malfunction.
      • When reassembling, make sure that each ribbon connector is completely inserted before lowering the black tab.
      Ask FixBot
    4. MSI GS65 Stealth Thin 8RE RAM Replacement: step 4, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 4, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 4, image 3 of 3
      • Unscrew the single 4 mm Phillips #00 screw securing the Wi-Fi card.
      • Remove the Wi-Fi card and the cable located next to it.
      • Be careful to not unplug the two wires next to the screw.
      • There will be a yellow tape covering the WiFi card that will need to be removed.
      • Make sure to keep the yellow tape to reapply on the Wi-Fi card when reassembling.
      Ask FixBot
    5. MSI GS65 Stealth Thin 8RE RAM Replacement: step 5, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 5, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 5, image 3 of 3
      • Remove the last two ZIF ribbon connectors.
      • Slowly unpeel the black ribbon connector from the fan.
      • When reassembling, make sure to adhere the black ribbon to the motherboard in a way that does not cover the fan.
      Ask FixBot
    6. MSI GS65 Stealth Thin 8RE RAM Replacement: step 6, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 6, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 6, image 3 of 3
      • Unscrew the two black 6 mm Phillips #00 screws below each fan.
      • Slightly lift the motherboard.
      • While the motherboard is lifted, thread the Wi-Fi card through the hole as shown.
      • There may be a piece of yellow tape holding the WiFi card wires down that needs to be removed.
      Ask FixBot
    7. MSI GS65 Stealth Thin 8RE RAM Replacement: step 7, image 1 of 2 MSI GS65 Stealth Thin 8RE RAM Replacement: step 7, image 2 of 2
      • Double-check that everything connected to the motherboard as shown in the previous steps has been removed.
      • Carefully remove the motherboard and flip it over.
      Ask FixBot
    8. MSI GS65 Stealth Thin 8RE RAM Replacement: step 8, image 1 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 8, image 2 of 3 MSI GS65 Stealth Thin 8RE RAM Replacement: step 8, image 3 of 3
      • Locate the RAM.
      • Carefully pull apart the silver arms holding the RAM down, and the RAM should pop up.
      • Pull the RAM out.
      • When inserting the new RAM, it will snap into place.
      Ask FixBot
4 other people completed this guide.
Annie Lin
265 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 142
All Time: 3,191
