HDD
1 Answer 0 Score |
FPS and Sudden heating issue while running any game |
1 Answer 0 Score |
Usb A port not working |
1 Answer 0 Score |
Unable to run the game due to BSOD video_dxgkrnl_fatal error. |
1 Answer 0 Score |
Laptop Shutdown sudden how to fixit |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Technical Specifications
Processor
- AMD Ryzen 5 4600H
- 6 Cores, 12 Threads
- 3.0 GHz Base, 4 GHz Turbo
- 3MB L2, 8MB L3 Cache
Graphics
- NVIDIA GeForce GTX 1650 Ti
- 4GB GDDR6
- 1350 MHz Base, 1485 MHz Boost
Monitor Support
- HDMI supports up to 4096x2160@60Hz
Memory
- Up to 16GB DDR4-3200 offering
- Two DDR4 SO-DIMM slots, dual-channel capable
Storage
- Up to two drives, 1x 2.5" HDD + 1x M.2 SSD
Speakers
- Stereo speakers, 1.5W x2, Dolby® Audio™
Microphone
- Dual array microphone
Camera
- HD 720p, with privacy shutter, fixed focus
Battery
- Integrated Li-Polymer 45Wh battery, supports Rapid Charge (charge up to 80% in 1hr)
Power Adapter
- 135W slim tip (3-pin) AC adapter, 100-240V, 50-60Hz
Display
- 15.6" FHD (1920x1080), IPS, 250 nits, Antiglare, 16:9, Refresh rate 60HZ, DC dimmer
Keyboard
- 6-row, multimedia Fn keys, numeric keypad
- Blue backlight
Touchpad
- Buttonless Mylar® surface multi-touch touchpad, supports Precision Touchpad (PTP), 69 x 104 mm (2.72 x 4.09 inches)
Dimensions (W x D x H)
- 359 x 249.6 x 24.9 mm (14.13 x 9.83 x 0.98 inches)
Weight
- 2.2 Kgs (4.8 lbs)
Onboard Ethernet
- Gigabit Ethernet
WLAN + Bluetooth
- 802.11ac 2x2 Wi-Fi® + Bluetooth 5.0, M.2 card
Standard Ports
- 2x USB 3.2 Gen 1
- 1x USB-C 3.2 Gen 1 (support data transfer only)
- 1x HDMI 2.0
- 1x Ethernet (RJ-45)
- 1x Headphone / microphone combo jack (3.5mm)
- 1x Power connector
