Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Krups CafeExpress FMA110 is a compact coffee maker released in October of 2001 with a brew capacity of 4-5 cups of coffee. It includes a permanent nylon filter that will replace disposable coffee filters, and the swing-out coffee ground holder makes for easy loading and disposal. Additionally, the “stop ‘n serve” feature allows you to remove the pot for up to 20 seconds during the brewing cycle so you can pour coffee while it’s still brewing. There is also a water level indicator on the outside of the device that shows you how much coffee is left to brew.
This device was discontinued by the manufacturer, so a brand new device of this model is hard to find. If you need to disassemble your device to repair it, follow the disassembly guide for this device
Identification
The Krups CafeExpress FMA110 has a unique design, which makes it distinguishable from other Krups coffee makers. Its model number can be found on a white sticker on the bottom of the device. It is printed under the barcode to the left of the forward slash.
Specifications
Physical Properties
  • Dimensions: 11.8 x 8.2 x 7.6 inches
  • Weight: 3.4 pounds
  • Color: White
  • Material: plastic body, nylon filter, glass pot
Electrical Specifications
  • Voltage: 120 Vac
  • Frequency: 60 Hz
  • Power Consumption: 700 W
Additional Information
Amazon Reviews
Ebay Reviews
alaTest Reviews
Author
with
Sam Sugerman
327 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 1,142
