Krups CafeExpress FMA110 Disassembly
    1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: step 1, image 1 of 2 Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: step 1, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
      • Remove the metal plate.
      Ask FixBot
    2. Krups CafeExpress FMA110 Disassembly: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
      Ask FixBot
    3. Krups CafeExpress FMA110 Disassembly: step 3, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 3, image 2 of 2
      • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
      Ask FixBot
    4. Krups CafeExpress FMA110 Disassembly: step 4, image 1 of 1
      • Carefully pull the silicon tubing off of the metal tube.
      Ask FixBot
    5. Krups CafeExpress FMA110 Disassembly: step 5, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 5, image 2 of 2
      • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
      Ask FixBot
    6. Krups CafeExpress FMA110 Disassembly: step 6, image 1 of 1
      • Carefully remove the silicon tubing from the upper reservoir.
      Ask FixBot
    7. Krups CafeExpress FMA110 Disassembly: step 7, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
      Ask FixBot
    8. Krups CafeExpress FMA110 Disassembly: step 8, image 1 of 1
      • Separate the base of the device from the upper reservoir.
      Ask FixBot
    9. Krups CafeExpress FMA110 Disassembly: step 9, image 1 of 1
      • Push the switch out from the inside, releasing it from the plastic base.
      Ask FixBot
    10. Krups CafeExpress FMA110 Disassembly: step 10, image 1 of 1
      • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
      Ask FixBot
    11. Krups CafeExpress FMA110 Disassembly: step 11, image 1 of 1
      • Slide the rest of the switch back through the hole in the base.
      Ask FixBot
    12. Krups CafeExpress FMA110 Disassembly: step 12, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 12, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
      Ask FixBot
    13. Krups CafeExpress FMA110 Disassembly: step 13, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 13, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
      Ask FixBot
    14. Krups CafeExpress FMA110 Disassembly: step 14, image 1 of 1
      • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
      Ask FixBot
    15. Krups CafeExpress FMA110 Disassembly: step 15, image 1 of 1
      • Disconnect the wire connectors from the thermal switch.
      Ask FixBot
    16. Krups CafeExpress FMA110 Disassembly: step 16, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
      Ask FixBot
    17. Krups CafeExpress FMA110 Disassembly: step 17, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 17, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
      • Separate the hot plate from its frame.
      Ask FixBot
    18. Krups CafeExpress FMA110 Disassembly: step 18, image 1 of 2 Krups CafeExpress FMA110 Disassembly: step 18, image 2 of 2
      • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 880
