Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Core Technical Specifications
The original Command series is largely categorized by its orientation: CH (Command Horizontal) and CV (Command Vertical). These engines are typically found in older high-end garden tractors and industrial equipment.
  • Valvetrain: Features an Overhead Valve (OHV) design. Crucially, most V-twin and many single-cylinder Command engines utilize hydraulic valve lifters, which automatically adjust to maintain zero lash, eliminating the need for periodic valve clearance adjustments.
  • Lubrication: Unlike consumer "splash" systems, the Command series uses a full-pressure lubrication system with a high-efficiency automotive-style spin-on oil filter, ensuring consistent oil flow to critical bearings even on slopes.
  • Bore & Sleeve: Constructed with an aluminum block and cast-iron cylinder liners, providing a durable wear surface that can be rebuilt—a key differentiator from cheaper "throw-away" residential engines.
  • Ignition: Uses a reliable electronic magneto ignition (specifically the Capacitive Discharge Ignition or CDI) that ensures a strong spark even at low cranking speeds for easier starting.
KOHLER Command CH18-CH25, CH620-CH730, CH740, CH750 Service Manual
Kohler Command PRO CH682, CH732, CH742 and CH752 Service Manual, Rev. C
Kohler Command LPG and LPG/NG-Fueled Engine Service Manual
KOHLER Command PRO ECV850, ECV860, ECV870, ECV880 Service Manual
KOHLER Command PRO ECH630–ECH749, CH735, CH26, CH745 Service Manual
KOHLER Command PRO CV682, CV732, CV742, CV752 Service Manual
SERVICE MANUAL KOHLER COMMAND CV17-750 VERTICAL CRANKSHAFT
Kohler Command CH18-750 Horizontal Crankshaft Service Manual
Kohler Command CH18-745 Horizontal Crankshaft Service Manual
Workman HD Series Service Manual
Kohler Command 11-16 HP Horizontal Crankshaft Owner's Manual
Kohler Command CH18-26 and CH730-740 Horizontal Crankshaft Owner's Manual
Kohler Command CH18-CH26 and CH620-CH750 Horizontal Crankshaft Owner's Manual
Toro Workman HD Series Service Manual (HD 07369, HDX/HDX-D Kubota Engines)
Kohler Command Series CH18-26 and CH730-745 Horizontal Crankshaft Owner's Manual
Kohler Command CV18–CV26, CV620–CV750 Vertical Crankshaft Owner's Manual
Kohler Engines Service Bulletins and TechTips Collection
COMMAND CH18-CH750 à arbre moteur horizontal — Manuel d'entretien
Husqvarna Kohler Command Pro 15Hp CV15S-41617 Illustrated Parts List
Kohler Command 26 hp CV730-0042 Spare Parts List
KOHLER COMMAND PRO 4.5–14 HP Engines Specifications
Kohler Command Series CH18-26, CH730-745 Horizontal Crankshaft Owner's Manual
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 87
All Time: 494
