Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background:
The Amazon Kindle 8 is a basic, entry-level e-reader that was released in July 2016. It allows users to read e-books without a glare although it lacks a built-in light. This requires external lighting for use in dark environments. The Kindle 8 only weighs 5.7 ounces.  The device includes Bluetooth connectivity, which is compatible with the VoiceView screen reader. The VoiceView feature was aimed at visually impaired users who can pair their Kindle with a Bluetooth audio device.
The Kindle was priced at $79.99 with ads and $99.99 without ads at launch. Its 4GB of storage can hold thousands of e-books and the battery life is rated for up to 14 hours of reading time. It lacks some features found in more expensive models, such as higher resolution and waterproof design, but it does have Amazon’s Kindle library that provides users with access to content. Consumer reviews have praised the Kindle 8 for its affordability and portability while some noted the screen’s contrast issues in bright light.
The Kindle 8 model followed the Kindle 7 with improvements in processing speed and a slimmer, more compact design. However, it was later succeeded by the Kindle 10, which was released in 2019. The Kindle 10 added a built-in light and continued to improve the design. The Kindle 8 ultimately fit in Amazon’s line-up as a basic option and remains a good choice for readers who prioritize simplicity and value.
Identification:
The Amazon Kindle 8 has a smooth plastic exterior which is available in two colors: black and white. It approximately measures 6.3 x 4.3 x 0.36 inches and weighs 5.7 ounces. The model number is located on the back of the device, at the bottom. Some distinctive features of the Kindle 8 are the lack of front light and its Bluetooth connectivity. It has a minimalistic design and compact size which differentiates it from other models.
Technical Specifications:
  • Body Color: Black, White
  • Display: 6-inch E Ink
  • Screen Resolution: 800 x 600 pixels and 167 PPI
  • Dimensions: 6.3 x 4.5 x 0.36 inches (160 x 115 x 9.1 mm)
  • Weight: 5.7 oz (161g)
  • Storage: 4 GB
  • Ram Memory: 512 MB
  • Connectivity: Bluetooth
  • Available Ports: Micro USB
  • Price at Launch: $79.99 with ads, $99.99 without ads
Sources:
Amazon Kindle (8th Gen) Reviews, Specs & Price Compare
Amazon Kindle 8th Generation 2016 Review - Good e-Reader
Additional Information:
Author
with
Jeremy
98 Reputation
0 Guides authored
Past 24 Hours: 6
Past 7 Days: 61
Past 30 Days: 291
All Time: 8,906
