Up to 20% off select tools
Amazon Kindle 8 Battery Replacement
Views: 7.9K
View statistics:
Past 24 Hours:
9
Past 7 Days:
99
Past 30 Days:
474
All Time:
7,873
Comments: 6
6 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If your Amazon Kindle 8 no longer holds a charge, drains quickly, or doesn't turn on, use this guide to replace the battery.
The battery provides power to the Kindle. Over time, batteries may degrade, which could affect performance and usability.
Before beginning, try basic troubleshooting steps like charging with a different cable or power adapter to ensure the issue lies with the battery.
Follow the steps carefully to avoid puncturing the battery, which could create a safety hazard.
    1. Amazon Kindle 8 Battery Replacement, Front Cover: step 1, image 1 of 2 Amazon Kindle 8 Battery Replacement, Front Cover: step 1, image 2 of 2
      • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
      • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
      • Keep even pressure to avoid any cracks.
      • Lift front cover once all clips are disengaged.
      • Lift the front cover gently so that it is not cracked.
      Ask FixBot
    2. Amazon Kindle 8 Battery Replacement: step 2, image 1 of 2 Amazon Kindle 8 Battery Replacement: step 2, image 2 of 2
      • Insert the spudger between the inner front cover and the screen.
      • Gently work your way around to loosen the inner front cover.
      • Carefully lift the inner front cover from the device.
      Ask FixBot
    1. Amazon Kindle 8 Battery Replacement, Motherboard: step 3, image 1 of 2 Amazon Kindle 8 Battery Replacement, Motherboard: step 3, image 2 of 2
      • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
      Ask FixBot
    2. Amazon Kindle 8 Battery Replacement: step 4, image 1 of 2 Amazon Kindle 8 Battery Replacement: step 4, image 2 of 2
      • Lift the screen and motherboard from the back cover.
      Ask FixBot
    1. Amazon Kindle 8 Battery Replacement, Battery: step 5, image 1 of 1
      • Pinch the clips on the battery and disconnect the battery connector from its socket.
      Ask FixBot
    2. Amazon Kindle 8 Battery Replacement: step 6, image 1 of 1
      • Insert the halberd spudger between the motherboard and battery.
      • Take care not to bend, twist, or puncture the battery.
      • Slowly move the spudger around the battery and pry it off.
      • The battery is glued in place, so don't be afraid to use some moderate force.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 other people completed this guide.
Author
with
Luke
468 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 99
Past 30 Days: 474
All Time: 7,873
