Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
For additional help with the Hover-1 Eagle, check out the device's troubleshooting page.
Background
The Hover-1 Eagle Scooter is an electric scooter that was released in 2019. With the lightweight chassis of 20 pounds and collapsible handlebar, the Hover-1 Eagle was designed with portability in mind.
This electric scooter tops out at 15 miles per hour with a 7 mile distance range per charge. The handlebars house an electronic throttle, a LED speedometer, and a LED headlight. The handlebar also internally houses the battery pack with a 4Ah capacity. The base of the electric scooter is where both 6.5 inch wheels are mounted to, and where the braking pad is placed.
Hover-1 has released similar models to the Eagle, but this model can be easily identified by its large blue cross on the deck.
Identification
Identified by model number: Hover-1EGAL
Specifications
  • Dimensions: 15.75 in x 45.75 in x 37.50 in
  • Weight: 20.88 lbs
  • Battery Capacity: 36V, 4.0 Ah, with overcharge and discharge protection
  • Weight Capacity: 264 lbs
  • Wheel Diameter: 6.5 in
  • Miscellaneous: Front Wheel Drive, LED headlight, Electronic throttle and foot brake, App connectivity with learning modes, 5-hour max charge time
Additional Information
Hover-1 Eagle Troubleshooting Page
Hover-1 Eagle Manual
Walmart Product Page
Hover-1 Eagle EU-H1-EGE Instrukcja obsługi
Eagle EU-H1-EGE Manuale d'uso
EU-H1-EGE Original Instruction
Eagle EU-H1-EGE Manual de uso
EU-H1-EGE Mode d'emploi
Eagle EU-H1-EGE Originele instructie
Author
with
Hector Delgado
51 Reputation
0 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
60 Guides authored
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 142
All Time: 23,823
