Hover-1 Eagle Front Wheel Replacement
  1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: step 1, image 1 of 1
    • Wedge the spudger underneath the red reflective sticker and peel it back.
    Ask FixBot
  2. Hover-1 Eagle Front Wheel Replacement: step 2, image 1 of 2 Hover-1 Eagle Front Wheel Replacement: step 2, image 2 of 2
    • Remove the four 2mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  3. Hover-1 Eagle Front Wheel Replacement: step 3, image 1 of 1
    • Remove the plastic axle cover by sliding the cover downwards.
    Ask FixBot
  4. Hover-1 Eagle Front Wheel Replacement: step 4, image 1 of 1
    • Use pliers to remove the locknut.
    Ask FixBot
  5. Hover-1 Eagle Front Wheel Replacement: step 5, image 1 of 1
    • Slide the wheel out in a downwards motion to remove it from the fork.
    Ask FixBot
5 other people completed this guide.
Andrew Gaskell
1,137 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
6 Guides authored
18 Guide Comments
Good afternoon.
And how do you remove the cables?
Diogo Silva - Reply Share
i would like to know the same thing
it'sluigiplays 87 - Reply Share
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - Reply Share
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - Reply Share
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - Reply Share
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 87
All Time: 7,955
