Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Track down problems encountered with your Garmin V on our Garmin GPS V Troubleshooting Page.
Background
The Garmin GPS V was released in 2002. The Garmin GPS V is encased in a rectangular plastic shell.
Identification
A white and yellow "GPS V" logo is printed on the scroll button on the front face. This is where the display and buttons are situated. A cylindrical plate protrudes from the back of the unit, housing the batteries. Use your device's serial number to confirm the model.
Technical Specifications
Power
Source: 8-35v DC, 4 “AA” batteries
Battery Life: 25 Hours
Physical
Size: 5.0"W x 2.3"H x 1.6"D (12.7 x 5.9 x 4.1 cm)
Weight: 9 ounces (255 g) w/batteries
Display: 2.2"W x 1.5"H (5.6 x 3.8 cm), 256 x 160 pixels, high-contrast FSTN with bright backlighting. Switchable orientation.
Case: Fully gasketed, high-impact plastic alloy, waterproof to IEC 529 IPX7 standards.
Temperature range: 5° F to 158° F (–15° C to 70° C)
User data storage: Indefinite, no memory battery required.
GPS Performance
Receiver: WAAS enabled, 12 parallel channel GPS receiver continuously tracks and uses up to 12 satellites to compute and update your position
Interfaces: RS232 with NMEA 0183, RTCM 104 DGPS data format and proprietary Garmin
Antenna: Detachable with standard BNC connector
Differential: RTCM-104, WAAS
Acquisition Times
Warm: Approximately 15 seconds
Cold: Approximately 45 seconds
AutoLocate®: Approximately 5 minutes
Update rate: 1/second, continuous
GPS Accuracy
Position: < 15 meters, 95% typical*
Velocity: 0.05 meter/sec steady state
WAAS accuracy
Position: < 3 meters, 95% typical
Dynamics: 6g's
Navigation Features
Waypoints/Icons: 500 with name and graphic symbol, 10 nearest (automatic), 10 proximity.
Routes: Automatic turn-by-turn routes; 20 manual point-to-point routes with up to 50 points each.
Tracks: Automatic track log; 10 saved tracks let you retrace your path in both directions
Trip computer: Resettable odometer, timers, average and maximum speeds
Alarms: Anchor drag, approach and arrival, off course and proximity waypoint
Tables: Built-in celestial tables for best times to fish and hunt, sun and moon rise/set based on date and location
Map datums: More than 100, plus user datum
Position format: Lat/Lon, UTM/UPS, Maidenhead, MGRS, Loran TDs and other grids, including user grid
Plotting/Moving Map Features
Basemap
Built-in routable Americas Autoroute or Atlantic Autoroute basemap with oceans, lakes, rivers, cities, interstates or major motorways, principal and major thoroughfares and political boundaries.
MapSource®
MapSource City Select CD is included with the Americas GPS V® and European City Select® with the Atlantic GPS V which gives you access to routable street-level detail, addresses, listings of restaurants, hotels and more. Compatible with most Garmin® MapSource products including MapSource BlueChart® marine cartography and Fishing Hot Spots™. Accepts up to 19 megabytes of downloaded map detail.
Additional Information
GPS V User Manual
GPS V Technical Specifications
GPS V Software (link1)
GPS V Software (link2)
GPS V CNET Review
Amazon Product Page
Garmin GPS V with WAAS Specifications
Garmin GPS V Navegador Pessoal Manual do Usuário e Guia de Referência
Garmin GPS V Personal Navigator Owner's Manual
Garmin GPS V Owner's Manual and Reference Guide
Author
with
Connor
194 Reputation
4 Guides authored
Cal Poly, Team 3-25, Amido Winter 2012 Member of Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Members
48 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 46
All Time: 8,697
