Up to 20% off select tools
Garmin GPS V Button Pad Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
104
All Time:
2,250
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
One of the main reasons we would replace a button pad is if the functions are not working properly or at all. The functions could be getting stuck if that is the case then the button pad will need to be replaced. Some of the tools needed to replace the button pad are a Phillips screwdriver, soldering iron, soldering wire, and a pair of tweezers. Some soldering skills will be needed to perform this repair.
    1. Garmin GPS V Button Pad Replacement, Logic Board: step 1, image 1 of 3 Garmin GPS V Button Pad Replacement, Logic Board: step 1, image 2 of 3 Garmin GPS V Button Pad Replacement, Logic Board: step 1, image 3 of 3
      • Orient the GPS V backside up.
      • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
      Ask FixBot
    2. Garmin GPS V Button Pad Replacement: step 2, image 1 of 2 Garmin GPS V Button Pad Replacement: step 2, image 2 of 2
      • With the spudger, gently pry the back plate off the unit starting at the corners.
      • Open the back plate about 35°, use the antenna side act like a hinge.
      • Do NOT remove the back plate all the way, there are cables connected to it.
      Ask FixBot
    3. Garmin GPS V Button Pad Replacement: step 3, image 1 of 2 Garmin GPS V Button Pad Replacement: step 3, image 2 of 2
      • Locate the white 8-pin connector on the logic board and disconnect it.
      • Open the device all the way, making sure to not disconnect the brown antenna wire.
      Ask FixBot
    4. Garmin GPS V Button Pad Replacement: step 4, image 1 of 2 Garmin GPS V Button Pad Replacement: step 4, image 2 of 2
      • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
      • You may need to rotate the device to get better access to the screw.
      Ask FixBot
    5. Garmin GPS V Button Pad Replacement: step 5, image 1 of 3 Garmin GPS V Button Pad Replacement: step 5, image 2 of 3 Garmin GPS V Button Pad Replacement: step 5, image 3 of 3
      • Locate the ribbon connector on the logic board.
      • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
      • With the spudger, gently work the ribbon cable out of the connector until it is free.
      Ask FixBot
    6. Garmin GPS V Button Pad Replacement: step 6, image 1 of 2 Garmin GPS V Button Pad Replacement: step 6, image 2 of 2
      • With the spudger, gently pry out the logic board.
      • Be careful to not disconnect the brown antenna wire as you remove the logic board.
      Ask FixBot
    7. Garmin GPS V Button Pad Replacement: step 7, image 1 of 1
      • Locate the brown wire connection on the logic board.
      • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
      • It may take some time to heat the flux up before the wire can be pulled out.
      • Pull brown wire free of the logic board.
      Ask FixBot
    1. Garmin GPS V Button Pad Replacement, Button Pad: step 8, image 1 of 3 Garmin GPS V Button Pad Replacement, Button Pad: step 8, image 2 of 3 Garmin GPS V Button Pad Replacement, Button Pad: step 8, image 3 of 3
      • Gently pry the button pad off of the front plate.
      Ask FixBot
3 other people completed this guide.
Author
with
Connor
194 Reputation
4 Guides authored
Cal Poly, Team 3-25, Amido Winter 2012 Member of Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Members
48 Guides authored
1 Guide Comment
Hey, a have an old Garmin GPS III and my problem is that the GPS can not find any satelliters. I have opened back plate and I think its looks ok inside.
What can I do?
Best regards
Christian Tregert
Ctregert@hotmail.com
ChristianTregert - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 104
All Time: 2,250
