Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
FirsTime wall clocks are battery-powered quartz clocks, usually running on a single AA battery. Common problems are a clock that stops or only runs intermittently, which is often caused by a weak battery, corroded or loose battery contacts, or a worn quartz movement. Cleaning the contacts and fitting a fresh battery will fix many cases; if the clock still does not run reliably, the quartz movement can usually be replaced as a unit.
Author
with
Samid Rehan
744 Reputation
1 Guide authored
Past 24 Hours: 8
Past 7 Days: 69
Past 30 Days: 193
All Time: 12,465
