Up to 20% off select tools
FirsTime Wall Clock Movemement Mechanism Replacement
Views: 15K
View statistics:
Past 24 Hours:
8
Past 7 Days:
69
Past 30 Days:
334
All Time:
15,335
Comments: 7
7 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This FastFix is provided so that you may be able to replace a broken FirsTime Wall Clock due to a faulty movement mechanism. This is helpful so you won’t have to spend money on replacing this item. It is a short and easy fix!
    1. FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: step 1, image 1 of 2 FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: step 1, image 2 of 2
      • Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
      Ask FixBot
    2. FirsTime Wall Clock Movemement Mechanism  Replacement: step 2, image 1 of 1
      • Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
      Ask FixBot
    3. FirsTime Wall Clock Movemement Mechanism  Replacement: step 3, image 1 of 2 FirsTime Wall Clock Movemement Mechanism  Replacement: step 3, image 2 of 2
      • Turn the display face up.
      • Use needle nose pliers to pull off the 'second' hand.
      Ask FixBot
    4. FirsTime Wall Clock Movemement Mechanism  Replacement: step 4, image 1 of 2 FirsTime Wall Clock Movemement Mechanism  Replacement: step 4, image 2 of 2
      • Use needle nose pliers to remove the 'minute' hand.
      • Then use needle nose pliers to remove the 'hour' hand.
      Ask FixBot
    5. FirsTime Wall Clock Movemement Mechanism  Replacement: step 5, image 1 of 1
      • Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
      • Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
      Ask FixBot
    6. FirsTime Wall Clock Movemement Mechanism  Replacement: step 6, image 1 of 2 FirsTime Wall Clock Movemement Mechanism  Replacement: step 6, image 2 of 2
      • Lift the washer underneath the nut with your fingers.
      Ask FixBot
    7. FirsTime Wall Clock Movemement Mechanism  Replacement: step 7, image 1 of 1
      • Now you may remove the display of the clock from your malfunctioning movement mechanism.
      Ask FixBot
26 other people completed this guide.
Author
with
Samid Rehan
744 Reputation
1 Guide authored
7 Guide Comments
Is there a you tube showing these steps?
Patricia Ander - Reply Share
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Leslie Benitez - Reply Share
Excellent illustrations!!!
KO SAMUEL TAK SHUN - Reply Share
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
Marcia Kaminski - Reply Share
Where can I buy the exact clock?
Barb - Reply Share
Past 24 Hours: 8
Past 7 Days: 69
Past 30 Days: 334
All Time: 15,335
