Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
A clamp meter differs from a standard multimeter in that it has a built in current clamp for measuring higher values of current and without having to break the circuit. They are very useful in testing appliance current draw, battery usage in RV and automotive use, as well as current in solar installations.
The 376 FC clamp meter uses an integrated low-pass filter for accurate measurements of non-linear signals, such as adjustable speed drives, electronic ballasts and other non-linear loads. The clamp also uses proprietary inrush measurement technology to filter out noise and capture motor starting current exactly as the circuit protection sees it.
Measure:
  • Voltage to 1000 V AC or DC
  • Resistance to 60 kΩ with continuity detection
  • Min, max, average, and inrush recording to capture variations automatically
  • 500 mV DC measurement range to interface with other accessories
  • 1000 μF capacitance measurement
  • Work safely and conveniently
  • The 376 FC clamp carries a CAT III 1000 V, CAT IV 600 V safety rating, designed to offer you the highest possible protection in a test tool.
Note: This is a great meter for general testing of HVAC, Automotive, Recreational Vehicles, and general home appliances . It is a rugged and simple to use meter. Due to this meter only going to 60K Ohm for resistance measurement, this is not the best option for a bench meter for someone who is getting heavily into electronics where measurement of higher resistances than 60K Ohm will be needed.
Fluke 370 FC Series True-rms Wireless AC/DC Clamp Meters Specifications
Fluke 370 FC Series True-rms Wireless AC/DC Clamp Meters Technical Data
Author
with
rickwag
1,906 Reputation
15 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 62
All Time: 1,121
