Up to 20% off select tools
FLUKE 376FC True-RMS Clamp Meter Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
85
All Time:
701
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a quick and simple guide to replace the batteries in this multimeter
    1. FLUKE 376FC True-RMS Clamp Meter Battery Replacement, Battery Replacement: step 1, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement, Battery Replacement: step 1, image 2 of 2
      • Make sure the meter is in the Off position
      • Turn the meter over and place it on a surface that won't scratch the display face.
      Ask FixBot
    2. FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 2, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 2, image 2 of 2
      • Using the flat blade screwdriver, rotate the battery locking key from the locked to the unlocked position. Be careful not to use a lot of force as the plastic can be easily damaged by the metal screwdriver.
      • The unlucky will show up on the top by the small arrow in the case.
      Ask FixBot
    3. FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 3, image 1 of 2 FLUKE 376FC True-RMS Clamp Meter Battery Replacement: step 3, image 2 of 2
      • Use your finger to pull open the battery compartment cover.
      • Replace your AA batteries.
      • Use the reverse instructions to reassemble your meter.
      Ask FixBot
Author
with
rickwag
1,906 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 85
All Time: 701
