Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The i-CON 1 is a compact, high-performance soldering station that is designed for use in professional electronics manufacturing and repair applications.
The i-CON 1 features a digital display that shows the temperature of the soldering iron in real-time, allowing users to easily adjust the temperature to the desired setting. The station also has a programmable temperature control, enabling users to store up to 20 different temperature settings for various soldering applications.
In addition, the i-CON 1 is equipped with a range of safety features, such as a sleep mode that automatically switches the soldering iron off when it is not in use, a low voltage mode that reduces power consumption when the iron is in standby mode, and a password protection function that prevents unauthorized access to the station's settings.
Additional Information
ERSA i-CON 1 estación de soldadura — Manual de instrucciones
Ersa EASY ARM 2 Solder Fume Extraction Operating Instructions (DE, EN)
ERSA i-CON 1 Lötstation Betriebsanleitung
Ersa — Оборудование и материалы для пайки: каталог продукции
Author
with
Sebastian
33,966 Reputation
72 Guides authored
German Translators Member of German Translators
Community
52 Members
6,638 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 70
All Time: 1,706
