Ersa i-CON 1 Display Replacement
    1. Ersa i-CON 1 Display Replacement, Remove the control knob: step 1, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Pull off the control knob using a nylon spudger.
      • Alternatively, a flat head screwdriver can be used, but be cautious of potential scratches on the metal faceplate.
      Ask FixBot
    2. Ersa i-CON 1 Display Replacement, Remove bottom screws: step 2, image 1 of 1
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      Buy
      • Flip the station over and remove the four T20 screws.
      • Flip the station back onto its base and lift the top cover up and off the station.
      Ask FixBot
    3. Ersa i-CON 1 Display Replacement, Remove display nuts: step 3, image 1 of 1
      • Use pliers or a wrench to unscrew the four plastic nuts holding the display in place.
      Ask FixBot
    4. Ersa i-CON 1 Display Replacement, Disconnect the display cable: step 4, image 1 of 1
      Spudger
      $3.99
      Buy
      • Carefully flip the display upwards.
      • Loosen the display connector by pushing up the small brown bars on both sides of the connector with a spudger or similar tool.
      • Pull the ribbon cable from the connector.
      Ask FixBot
3 other people completed this guide.
Sebastian
33,675 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 66
All Time: 912
