Up to 20% off select tools
Guides
Troubleshooting
To resolve common issues with the ecobee SmartThermostat EB-STATE5-01, refer to this link.
Background
The ecobee SmartThermostat with VoiceControl has the model number EB-STATE05-01. It was released June 3, 2019 at $249 (USD). It is one of the smaller versions that they have released, at 4.29 x 4.29 x 1 inches. It has a wireless sensor, as opposed to the wired sensor that the two earliest models had. This device is similar in design to its predecessors
There are no reported recalls on this device currently. The ecobee company was recently bought out by Generac, a Canadian home automation company.
Identification
The ecobee SmartThermostat with VoiceControl and other ecobee smart thermostats all look very similar, with small differences in between them. This device has a rounded white back and black display, while similar models have a flat silver back and black display. This device includes a smart sensor in the box, while previous models do not. It is also equipped with Siri and Amazon Alexa capabilities, while previous models are not. To identify the model number of the thermostat on the thermostat, tap the screen and then tap the hamburger menu button (3 parallel horizontal lines in a stack). Tap "About". The steps are the same for the app.
Technical Specifications
Display:
3.5 in. full-color LED touchscreen
320 x 480 pixel display
Dimensions:
Thermostat:
  • Height: 109 mm (4.29 in.)
  • Width: 109 mm (4.29 in.)
  • Depth: 25.6 mm (1 in.)
SmartSensor:
  • Height: 40 mm (1.6 in.)
  • With stand: 50 mm (2 in.)
  • Width: 40 mm (1.6 in.)
  • Depth: 26 mm (1 in.)
Trim plate:
  • Height: 158.6 mm (6.2 in.)
  • Width: 158.6 mm (6.2 in.)
  • Depth: 8.7 mm (0.3 in.)
Power Extender Kit*:
  • Length: 62 mm (2.4 in.)
  • Width: 62 mm (2.4 in.)
  • Depth: 23 mm (0.9 in.)
  • *Optional for installation
Processor + Memory:
  • 1.5GHz quad-core Cortex A35 processor
  • 4GB Flash (eMMC)
  • 512MB DDR4 RAM
Power consumption + methods:
  • Up to 3.5 VA
  • Wired 24VAC through terminals C and Rc.
  • Power Extender Kit enables you to reliably power your thermostat without having to run a fifth wire.
Compatibility:
  • Gas, Oil, Electric, Dual-fuel
  • Conventional (2H/2C)
  • Heat Pump (4H/2C)
  • Humidifier, Dehumidifier, Ventilator, HRV or ERV
Wire Terminals:
  • c
  • G
  • Y1
  • Y2
  • O/B
  • PEK
  • Rh
  • C
  • W1
  • W2
  • ACC-
  • ACC+
Audiovisual:
  • Built-in Alexa Voice Service
  • Built-in microphones
  • Built-in speaker
  • Far-field voice recognition
Colors:
  • Front: Black
  • Sides: White
  • Back: White
Thermostat Sensors:
  • Temperature
  • Humidity
  • Occupancy
  • Proximity
Connectivity + Security:
  • Dual-band Wi-Fi: 802.11 b/g/n @ 2.4GHz, 802.11 a/n/ac @ 5GHz
  • Bluetooth 5.0
  • WEP 64, WEP 128, WPA, and WPA2 encryption methods
  • DHCP (dynamic) or static IP addressing
  • 168-bit SSL encryption
  • 915MHz radio
Temperature Range:
  • Desired Temperature: 45° to 92°F (7° to 33°C)
  • Display: 40° to 100°F (5° to 37°C)
  • Sensitivity: +/− 1°F (+/− 0.5°C)
  • Operating: 32° to 130°F (0° to 55°C)
Additional Information
ecobee SmartThermostat with VoiceControl's Amazon Page
ecobee SmartThermostat with VoiceControl's Tom's Guide Page
Installation Guide for ecobee SmartThermostat with VoiceControl
ecobee's Thermostat FAQs
ecobee's "Get to Know Your Smart Thermostat"
Author
with
dailynne major
137 Reputation
0 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 48
All Time: 1,326
