Armature
1 Answer 0 Score |
Will somewhat run if the brush caps are squeezed together, how to fix? |
1 Answer 2 Score |
Why is my device running at inconsistent speeds? |
1 Answer 5 Score |
Why is my Device not turning on? |
1 Answer 0 Score |
Dremel 3000 will only work when pressing side lid |
Documents
Tools
Background
The Dremel MultiPro 395 is a rotary tool manufactured by the Dremel company. The MultiPro 395 has a speed between 5,000-35,000rpm, which is displayed on the label on the front. The MultiPro came with a comfort grip and was double insulated to eliminate the need for grounding. The MultiPro initially sold for $96.89 and weighs about 2 pounds. The MultiPro was later replaced by the Dremel 3000 a few years later and was retired by the Dremel company.
Identification
The MultiPro is easily identified by the label on the front which says Dremel MultiPro, the model number and the speed at which it runs. The MultiPro can also be identified by the blue caps on either side of the MultiPro as well as the blue variable speed switch.
Additional Information
Dremel MulitPro 395 owner’s manual
Dremel Multi Pro and Minimite Tools Catalog
Dremel 670 Mini Saw Attachment Operating/Safety Instructions (EN, FR, ES)
Dremel 670 Mini Saw Attachment Operating and Safety Instructions (EN, FR, ES)
Dremel 285/395 Instructions (EN, DE, FR, NL, SV, NO, FI, DA, IT, ES, PT, EL, HU, CS, PL, TR, RU)
Dremel MultiPro 275T6, 285T6 and 395T6 Rotary Tool Owner's Manual (EN, FR, ES)
Dremel Power Tools Product Catalog
Dremel MultiPro Rotary Tool Owner's Manual (EN, FR, ES)
Dremel MultiPro Outil rotatif — Manuel de l'utilisateur
Dremel Model 670 Mini Saw Attachment Operating and Safety Instructions (EN, FR, ES)
