Dremel MultiPro 395 Carbon Brushes Replacement
  1. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: step 1, image 1 of 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: step 1, image 2 of 2
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    • Remove the blue caps located on either side of the MultiPro using a 3 mm flathead screwdriver.
    Ask FixBot
  2. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: step 2, image 1 of 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: step 2, image 2 of 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
    Ask FixBot
  3. Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: step 3, image 1 of 2 Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: step 3, image 2 of 2
    • Carefully insert the new carbon brushes into the location of the old carbon brushes using your hands.
    Ask FixBot
6 other people completed this guide.
3 Guide Comments
Yeah. And if you've overheated your Dremel to the point where it quits running, the brushes may be melted in place. Disassemble the two halves of the case, and push against the brushes from the inside, using the armature. After they pop free, you'll probably find that your switch has melted as well. Return the whole thing to Dremel, and if they can't fix it cheaply, they'll give you a good deal on an upgrade to a newer model. Cheers!
Tor Matson - Reply Share
How strongly are the brush springs attached to the carbon brushes? My brushes do not look very worn, they measure .2445" (carbon block only). However, one side the spring and the brush make contact but are not held together by anything other than the spring tension. Is this a problem?
mycle85719 - Reply Share
I still have approx 1.5 cans on the brushes but it has stopped working, do they need changing?
jamessteele2 - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 78
All Time: 15,304
