Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Dolce Gusto Oblo is a single-use coffee machine by Nescafe, a Nestle company. It is manufactured by Krups. It’s easily recognized by its round shape. It makes americano, espresso, lattes, cappuccinos and other flavors using Nespresso brand single-use pods.
The Dolce Gusto Oblo is a “consumer-grade pressure-based automatic capsule coffee machine” according to the official site. The machine uses up to 15 bars of pressure for coffee extraction. It has a patented capsule that is sealed to keep the coffee fresh every time you make it. You also have the ability to customize your cup to be hot or cold using toggle stick, of coffee you want and you can adjust manually the strength of your brew.
It has a removable reservoir on the back, a height-adjustable drip tray, and an Eco-mode which automatically turns the machine off after 5 minutes of inactivity. This model was available in various colors such as orange, black, red, gray and white.
Common issues
A common issue with this device is water that leaks between the water tank connector and the water tank itself when it's unused and has water remaining on it's tank.
Technical Specs
  • Water Tank Capacity: 800ml
  • Capsule Bin: No
  • Machine Size: 18 D x 24.5 W x 31.5 H cm
  • Machine Weight: ‎2.5 kg
  • Machine Wattage: 1000 W/230 V, 50/60Hz
  • Machine Warranty: 2 years
  • Automatic shutdown for energy saving: Yes
Spare Parts Schema (with references)
Additional Informations
Author
with
Brendan
54,922 Reputation
3 Guides authored
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 193
All Time: 7,325
