Guides
2 Diagrams
Background
The DeWalt Air Compressor DWFP5126 is an air compressor designed for supporting pneumatic and air powered applications such as using power tools like an impact driver and a saw or supporting an air brush for sanding or painting.
The intended user for this compressor is anyone who needs a portable compressor to use for power tools or simple garage use.
While there has not been a recall on this specific model, its previous model, the D55143, had a recall in 2005 for a shock hazard due to lack of insulation around the motor lead wire. Its reviewers have one main complaint about this product leaking but can be fixed quite easily. It features a 165psi 6-gallon tank, a 90psi pump and a ball drain valve for emptying the tank. The compressors total weight is 30 pounds.
This air compressor was released in 2016 and is still being produced. This product can be bought anywhere in the world with DeWalt shipping internationally. You can get the product from a variety of sellers online and in person for $199.
Identification
This air compressor is roughly 18 inches tall and 16 inches wide and deep with a round yellow base that says DEWALT along with 3 black rubber feet that hold it up. The black pump is on the top of the tank and has a black handle. On the pump, right below the power switch, there are 2 gauges facing up. There are also 2 spots for air hoses rather than 1 like most compressors.
Technical Specifications
Body
  • Height - 17.5 in.
  • Width - 16.0 in.
  • Depth - 16.0 in.
  • Weight - 33 lbs.
  • Tank Size - 6 gal
Electrical
  • Power Output - 120V
  • Amperage - 15A
  • Power source - Corded
  • Fuse Type - Time Delay
  • Plug - Type B American Plug
Performance
  • Tank Pressure - 7-165psi
  • Pump Pressure - 2.6 SCFM at 90psi
  • Noise - 75.5dB
  • Pump Type - Oil Free
  • Air Hose Connection - Quick Connect
Sources:
Heavy Duty 165 PSI Pancake Compressor
N331539_DWFP55126.pdf (dewalt.com)
Tool Nerds Review
Additional Information
User Manual - Provides any technical information regarding the air compressor. It gives information on setup, operation, maintenance and troubleshooting.
Compressor Diagram - This diagram shows where all the parts are located for the DeWalt Air Compressor DWFP55126 Repair.
Pump Diagram - This diagram shows where all the parts are on the air pump specifically.
Sarah Westberg
43,388 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 152
All Time: 4,278
