Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild
    1. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: step 1, image 1 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: step 1, image 2 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove manifold cover: step 1, image 3 of 3
      • Disconnect the power cord, depressurize the compressor tank, and remove any hoses before starting this repair.
      • Use a long-shank T10 driver to remove the manifold cover screw.
      • Lift the cover directly up off of the gauges to remove.
      Ask FixBot
    1. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: step 2, image 1 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: step 2, image 2 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator knob: step 2, image 3 of 3
      • Twist the regulator control knob counterclockwise. When you feel resistance, continue to twist to break the knob free.
      • This may take a lot of force.
      • Remove the knob.
      Ask FixBot
    2. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 3, image 1 of 1
      • Remove the spring from inside the regulator control knob.
      Ask FixBot
    3. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: step 4, image 1 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: step 4, image 2 of 3 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Remove regulator internals: step 4, image 3 of 3
      • Use needle nose pliers to remove the fitting.
      Ask FixBot
    4. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 5, image 1 of 2 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 5, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the pressure regulator assembly from inside the manifold.
      • Use needle nose pliers to remove the regulator assembly.
      Ask FixBot
    5. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Assemble new regulator internals: step 6, image 1 of 2 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild, Assemble new regulator internals: step 6, image 2 of 2
      • The next three steps describe how to assemble the new regulator assembly.
      • Install the new o-ring on the new screw fitting by sliding it over the threads. Make sure it sits flush on the head of the screw fitting, directly above the threads.
      Ask FixBot
    6. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 7, image 1 of 2 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 7, image 2 of 2
      • Seat the narrow end of the new cap into one end of the new spring.
      Ask FixBot
    7. Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 8, image 1 of 2 Dewalt Air Compressor DWFP55126 2016 Regulator Rebuild: step 8, image 2 of 2
      • Slide the cap and spring, cap first, into the opening on the screw fitting to complete the new regulator internals.
      • Reassembly tip: some of these components are not firmly attached to each other, so reinstall carefully, being sure everything lines up.
      Ask FixBot
3 other people completed this guide.
Carsten Frauenheim
168,890 Reputation
437 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,252 Guides authored
9 Guide Comments
Perfecto... buena ilustracion y mejor explicación.Gracias.
Arturo - Reply Share
Any instructions for the Type 2 regulator?
James Figuracion - Reply Share
My regulator does not have a gauge. It only has a "min/max" knob. Will this kit work?
Vickie Hills - Reply Share
I have the DeWalt DWFP55126 Type 2 compressor with the broken regulator. Both the 5140147-52 or the 5140147-53 screw in valve seat are too small of a diameter. The seat diameter of mine is about 19/64 while both of the 5140147-52 and 5140147-53 are 27/64.
Nick - Reply Share
Nick, I have the same compressor with the same problem. DeWalt sent me the "53 kit" and I bought the "52". Neither are correct. What did you do to fix the problem
Tracy Ireland - Reply Share
Past 24 Hours: 4
Past 7 Days: 53
Past 30 Days: 262
All Time: 7,279
