Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background:
This is a food processor released by Cuisinart in 2014. It features one main motor to spin the rotator blades in the processor. In order to activate the motors, the cup attachment must be placed onto the food processor for safety purposes—there is a small weight activated button on the top surface of the processor. The cup attachment, not pictured, has a volume of 14 cups . The food processor has a secondary, alternate speed for dough mixing. It is currently discontinued and no longer for sale. There have not been any known manufacture recalls since its release.
Identification:
To identify your product, look for the serial number "DLC-2014CHB" on the bottom of the food processor.
Technical Specifications
  • Around 1.5KG/4LBS in weight
  • Draws between 750 to 1250 watts when motor is spinning/in use (depends on the mode: dough, normal, pulse).
  • Operating temperature range: N/A; does not heat up
Additional Information:
Cuisinart BDH-2 Blade and Disc Holder Instruction Booklet
Author
with
Justin Liu
171 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 555
