Introduction
This guide will show you how to disassemble a Cuisinart PowerPrep Plus DLC-2014CHB. Potential hazards may include the heavy weight of the food processor; do the disassembly on a flat, wide surface to avoid any risk of dropping and to ensure that the device is properly supported. This repair may be needed because of a misaligned/faulty weight sensor, burnt out LEDs, faulty motor, etc.
Remove four 17 mm screws from the bottom panel of the processor with a Phillips #2 screwdriver.
Remove the bottom panel from the main food processor chassis.
This device operates by first detecting the cup through a weight sensor. Then, by pressing pulse, on, or dough, the motor rotates a rod which the blade attachment fits onto.
There is an on/off button which turns the various components on, and the lights indicate which modes are active. The motor does not heat up enough for a need for temp regulation.
