Briggs and Stratton 675 Series Spark Plug Replacement
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: step 1, image 1 of 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: step 1, image 2 of 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
    Ask FixBot
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 1 of 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 2 of 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 3 of 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
    Ask FixBot
7 other people completed this guide.
Andrew Saunders
1,065 Reputation
2 Guides authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
19 Guides authored
14 Guide Comments
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Reply Share
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
pinch the front of black cap and pull off
tracy.mullen - Reply Share
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Reply Share
just remove the plug and take it with you
when buying a new plug
Bill - Reply Share
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 209
All Time: 53,082
