Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Black and Decker Pivot Plus PD600 rechargeable drill and screwdriver is a powerful 6 volt power-tool that provides a choice between a high-speed drilling setting for power and a low-speed setting for driving. This compact drill that was first made available in late 2001 features a three position handle that allows you to work in tight spaces, and an integrated LED light for visibility in dark areas. The 6-volt battery offers a long operating life as well as easy portability, and the quick-release mechanism in the head makes changing bits fast, safe and effortless.
Identification
The model number can be found above the warning label on the front of the drill.
Additional Information
Black and Decker Pivot Plus PD600 Manufacturers Website
Black and Decker Pivot Plus PD600 Replacement Parts
Black and Decker Pivot Plus PD600 Customer Reviews
Black and Decker Pivot Plus PD600 Instructions Manual
Amazon Product Page
Author
with
Jonathon Centofranchi
335 Reputation
3 Guides authored
Cal Poly, Team 4-15, Maness Spring 2013 Member of Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Members
72 Guides authored
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 76
All Time: 9,421
