Black and Decker Pivot Plus PD600 Pivot Button Disassembly
    1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: step 1, image 1 of 2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: step 1, image 2 of 2
      • Locate the pivot button screw labeled with a lock symbol.
      • Remove the screw with a Phillips #1 screwdriver.
      Ask FixBot
    2. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: step 2, image 1 of 2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly: step 2, image 2 of 2
      • Set the screw to the side.
      • Remove both sides of the button from the screwdriver.
      • You will be left with three pieces: a black piece with a lock on the front, a circular orange piece, and a spring.
      Ask FixBot
Ryan Angelich
101 Reputation
1 Guide authored
Cal Poly, Team 4-15, Maness Spring 2013 Member of Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 84
All Time: 1,696
