Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Bissell Cleanview Compact Turbo 3437F is a vacuum cleaner used to remove dust, pet hair, dirt and more from your floors. Additionally, with a detachable hose and a variety of additional attachments, the Bissell Cleanview Compact Turbo 3437F is capable of cleaning hard to reach areas on your walls and shelves. This device connects to a standard home outlet and has a 25 foot long cord so you can clean multiple rooms without unplugging the vacuum.
This vacuum emphasizes its lightweight model only weighing 10 pounds. The vacuum was marketed towards the elderly as a tall yet light vacuum that would not force users to bend over or do any heavy lifting in order to keep their homes clean.
This model is an upright vacuum rather than a canister model. This means that the dust container is attached to the vacuum itself and is not a separate component that has to be carried with the motor piece. Upright vacuums are generally regarded as easier to use and store than canister vacuums. However, they are typically noted to be much heavier, which is why Bissell designed the Compact Turbo in order to create a vacuum that minimizes this drawback.
Identification
The Bissell Cleanview Compact Turbo 3437F can be identified by the sticker on the vacuum behind the dust container. If you face the front of the vacuum, the sticker should be on the left side of the vacuum slightly hidden behind the hose. The sticker should have the exact device name and model number.
Technical Specifications
Measurements
  • Weight: 10 pounds
  • Cord Length: 25 feet
  • Hose Length: 5 feet
Power and Connectivity
  • Power Rating: 6.2 Amps
  • Power Source: Corded
  • Brush System: Rotating
  • Brush On/Off switch: No
  • Automatic Cord Rewind: No
Dirt Collection
  • Surface Type: Carpet, rugs, bare floor, hardwood, pet beds, multi-surface, sealed wood floors, upholstery, fabric
  • Cleaning System: Cyclonic
  • Cleaning Path Width: 10 inches
  • Surface Height Settings: 3
  • Bag Type: Bagless
  • Dirt Container Capacity: 1 Liter
  • Easy Empty Dirt Cup: Yes
  • Swivel Head: No
  • Edge Sweep Brushes: No
Source: Bissell Cleanview Compact Turbo 3437F Specifications
Additional Information
Bissell Cleanview Compact Turbo 3437F Assembly & Usage Guide
Bissell Cleanview Compact Turbo 3437F User Manual
Bissell Cleanview Compact Turbo 3437F Manufacturer Page & Reviews
Bissell Cleanview Compact Turbo 3437F on Amazon
Author
with
Justin Hite
765 Reputation
7 Guides authored
CSU Sacramento, Team 2-1, Laflen Fall 2024 Member of CSU Sacramento, Team 2-1, Laflen Fall 2024
CSUSAC-LAFLEN-F24S2G1
1 Member
84 Guides authored
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 56
All Time: 992
