Introduction
This is a replacement guide for the access plate of the Bissell Cleanview Compact Turbo 3437F. The access plate secures the brush roll and vacuum belt in place while the vacuum is on. Without the access plate, the brush roll would fall out of place and the entire vacuum would not function properly.
Use a Phillips #1 screwdriver to remove the six 20mm screws on the bottom of the vacuum.
