Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Bendix S1200 is the largest and heaviest but is less prone to cracking. This magneto has TMC casted into the housing.
Bendix S4LN-xxx, S4RN-xxx, S6LN-xxx, S6LN-xxx are the most common types of magnetos.
The Bendix magneto, also known as an ignition magneto, was developed by Andre Boudeville but perfected by Robert Bosch and Frederick Richard Simms. The magneto is a permanent electrical generator that produces high voltage for spark plugs. The magneto is used in aviation because it is more reliable than a battery coil system.
This specific Magneto’s responsibility is to ignite the fuel in the engine of the helicopter. It is an electrical generator that creates impulses of high voltage that are needed in order for the helicopter to become airborne.
Identification
The part number, S6RN-23, can be located on the name-plate on the magneto.
Additional Information
How Stuff Works (magneto)
Ignition system functions
Univair Engine and Fuel System Catalog
Author
with
Kelsi English
561 Reputation
5 Guides authored
Cal Poly, Team 1-2, Propen Fall 2012 Member of Cal Poly, Team 1-2, Propen Fall 2012
CPSU-PROPEN-F12S1G2
4 Members
60 Guides authored
Past 24 Hours: 7
Past 7 Days: 72
Past 30 Days: 269
All Time: 28,223
