Up to 20% off select tools
Bendix Magneto Impuse coupling replacement
Views: 7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
140
All Time:
7,018
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
A failed impulse coupling can cause the crankshaft gear to break off. This will cause the aircraft's magneto not to work therefore the aircraft's engine will not start.
    1. Bendix Magneto Impuse coupling replacement, Impulse Coupling: step 1, image 1 of 2 Bendix Magneto Impuse coupling replacement, Impulse Coupling: step 1, image 2 of 2
      • Use a 9/16 wrench to unscrew the nut on the drive shaft.
      Ask FixBot
    2. Bendix Magneto Impuse coupling replacement: step 2, image 1 of 1
      • Remove the lock washer underneath the nut.
      Ask FixBot
    3. Bendix Magneto Impuse coupling replacement: step 3, image 1 of 2 Bendix Magneto Impuse coupling replacement: step 3, image 2 of 2
      • Pull away the impulse coupling.
      Ask FixBot
3 other people completed this guide.
Author
with
Kelsi English
561 Reputation
5 Guides authored
Cal Poly, Team 1-2, Propen Fall 2012 Member of Cal Poly, Team 1-2, Propen Fall 2012
CPSU-PROPEN-F12S1G2
4 Members
60 Guides authored
2 Guide Comments
OK now I need to fix my Boeing 737-Max 8
ein Stein - Reply Share
Does it have timing
Matvio - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 140
All Time: 7,018
