Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Amazon Echo 2nd Generation was released on October 31, 2017, featuring Bluetooth connectivity and Amazon's Alexa. It is 5.8" x 3.4" x 3.4" (148mm x 88mm x 88mm) and weighs approximately 29 oz. (821 grams).
The Bluetooth smart speaker that features Alexa, a cloud-based voice service that can answer questions and play music.
Identification
Its appearance varies based on the cover material, which can have a fabric, metallic, or wood finish. The 5.8-inch Bluetooth speaker has a cylindrical shape. This iteration of the Echo is distinguishable from the 1st generation by its shorter height and slightly thicker body.
The Amazon logo is printed near the bottom edge of the speaker. You can identify your Amazon Echo 2nd Generation by the model and serial numbers on the original packaging.
Additional Information
Author
with
Billy Pho
491 Reputation
2 Guides authored
Cal Poly, Team S4-G4, White Fall 2018 Member of Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Members
60 Guides authored
Past 24 Hours: 15
Past 7 Days: 99
Past 30 Days: 359
All Time: 16,240
