Amazon Echo 2nd Generation MIC Board Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
112
All Time:
4,164
Comments: 16
15 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this replacement guide if you are experiencing issues with the user interface of this device (e.g. buttons are not working, LEDs are dead, no voice recognition).
Tools
  • TR8 Torx Security Screwdriver
    4.9
  • Spudger
    4.9
    1. Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: step 1, image 1 of 3 Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: step 1, image 2 of 3 Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: step 1, image 3 of 3
      • Remove the rubber layer beneath the device.
      • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
      • Remove the four 8.0 mm T8 Torx screws on the lid.
      • Remove the lid from the device.
      Ask FixBot
    2. Amazon Echo 2nd Generation MIC Board Replacement: step 2, image 1 of 3 Amazon Echo 2nd Generation MIC Board Replacement: step 2, image 2 of 3 Amazon Echo 2nd Generation MIC Board Replacement: step 2, image 3 of 3
      • Use a spudger to flip up the small flap on the ZIF connector.
      • Gently pull the ribbon cable out of the ZIF connector.
      • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
      Ask FixBot
    3. Amazon Echo 2nd Generation MIC Board Replacement: step 3, image 1 of 2 Amazon Echo 2nd Generation MIC Board Replacement: step 3, image 2 of 2
      • Use a spudger to lift up one of the small flaps on only one side of the female connector.
      • Pull on the wire toward the lifted side until the male connector is disconnected.
      • Remove the AMP Board.
      Ask FixBot
    1. Amazon Echo 2nd Generation MIC Board Replacement, Subwoofer (speaker): step 4, image 1 of 2 Amazon Echo 2nd Generation MIC Board Replacement, Subwoofer (speaker): step 4, image 2 of 2
      • Remove the four 30.0 mm T8 Torx screws in the corners.
      • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
      Ask FixBot
    2. Amazon Echo 2nd Generation MIC Board Replacement: step 5, image 1 of 2 Amazon Echo 2nd Generation MIC Board Replacement: step 5, image 2 of 2
      • Remove the lid on top of the subwoofer.
      • Flip the device over and let the subwoofer fall into your hand.
      • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
      Ask FixBot
    1. Amazon Echo 2nd Generation MIC Board Replacement, Front Cover Panel: step 6, image 1 of 2 Amazon Echo 2nd Generation MIC Board Replacement, Front Cover Panel: step 6, image 2 of 2
      • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
      • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
      • Flip the device over while supporting the front panel side.
      • Remove the front panel cover by lifting it.
      Ask FixBot
    1. Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: step 7, image 1 of 3 Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: step 7, image 2 of 3 Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: step 7, image 3 of 3
      • Lift the MIC board over and lay it down against a surface.
      • Disconnect the ribbon cable from the MIC board and pull the board away.
      Ask FixBot
Billy Pho
491 Reputation
2 Guides authored
Cal Poly, Team S4-G4, White Fall 2018 Member of Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Members
60 Guides authored
1 Guide Comment
Is there a place to buy a replacement MIC Board?
Michael Petrucci - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 112
All Time: 4,164
