Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The ASUS Portable AiO PT2001 was released in mid-2014. Its portable design breaks the traditions of a desktop and makes it convenient to carry around. It contains laptop hardware, with a hyperthreaded dual-core i5-4200U clocked at 1.6GHz (with turbo boost to 2.6GHz). This CPU is paired to 8GB of DDR3-1333 RAM and a Nvidia Geforce 820M graphics card with 1GB of video RAM. The display is a 19.5” IPS touch screen display with a maximum resolution of 1600x900. This PC contains a host of peripheral ports, including 2 USB 3.0 ports, a USB 2.0 port, a 3-in-1 Card Reader (SD/SDHC/MMC), a 3.5mm audio jack, and separate HDMI-in and HDMI-out ports. The HDMI-in port allows the computer to be used as an external display for another computer. This AiO also contains battery which is rated for 5 hours of usage, according to ASUS.
Identification
The ASUS Portable AiO PT2001 can be identified by the model number on the label located on the bottom of the back case of the device under the kick stand. For additional help with identifying your device, visit the Asus Support page.
Additional Information
ASUS Portable AiO PT2001 Buying Guide - Lifewire
Product Website
Video Overview
ASUS Portable AiO PT2001 on Amazon
ASUS PT2001 Series All-in-One PC Käyttöopas
ASUS All-in-One PC Guía de usuario
Author
with
Vinu Weerasinghe
381 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Livingston Spring 2018 Member of Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Members
96 Guides authored
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 66
All Time: 6,556
