ASUS Portable AiO PT2001 Wireless Card Replacement
  1. ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: step 1, image 1 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: step 1, image 2 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement, Back Panel: step 1, image 3 of 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
    Ask FixBot
  2. ASUS Portable AiO PT2001 Wireless Card Replacement: step 2, image 1 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement: step 2, image 2 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement: step 2, image 3 of 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
    Ask FixBot
  3. ASUS Portable AiO PT2001 Wireless Card Replacement: step 3, image 1 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement: step 3, image 2 of 3 ASUS Portable AiO PT2001 Wireless Card Replacement: step 3, image 3 of 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
    Ask FixBot
  4. ASUS Portable AiO PT2001 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
    • The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
    Ask FixBot
  5. ASUS Portable AiO PT2001 Wireless Card Replacement: step 5, image 1 of 2 ASUS Portable AiO PT2001 Wireless Card Replacement: step 5, image 2 of 2
    • Remove the 3.5 mm Phillips #1 screw from the wireless card.
    • Remove the connectors by pulling straight up on their ends.
    Ask FixBot
  6. ASUS Portable AiO PT2001 Wireless Card Replacement: step 6, image 1 of 2 ASUS Portable AiO PT2001 Wireless Card Replacement: step 6, image 2 of 2
    • Remove the wireless card from the casing by lifting up then pulling out.
    • The wireless card is fragile. Be careful when pulling it out of the casing.
    Ask FixBot
Erich Fenczik Warnock
193 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Livingston Spring 2018 Member of Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 954
