The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube and the Nintendo Wii, and to a more limited extent, the Nintendo Wii U and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
Left D-Pad always moving up.
I have tried unplugging and re-plugging the remote multiple times and done everything I know how to. On occasion it will let you move other directions but then it will start going straight up no matter what. Are the Potentiometers in the D-pad damaged or might it be the micro chip. Mine is the kind with the blue face and the clear back.
1 Comment
First off, just wondering if you tried to hold down the X, Y,and start buttons for three seconds. This resets the controller
by
Add a comment
1 Answer
Chosen Solution
Michael Stucki, the first thing I would do, is to clean it. Use this video as a guide. After that, re-evaluate and see what you got. The drifting is usually not part of an IC control. I found that if any IC goes, there is no movement.
Score 1
Add a comment
Add your answer
Michael Stucki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 4,396
