Up to 20% off select tools
The 5th Generation Hilux introduced in 1988, produced a longer-wheelbase option, 3,099 mm (122 in) rather than 2,616 mm (103 in) for the regular wheelbase. Its one-piece cargo-box walls eliminated the rust-prone seams that were found in earlier models.
My keys are stuck
my keys are stuck
1 Comment
Stuck in door lock cylinder, ignition switch or trunk lock? The steering column lock and shift lock (when shifter isn't in Park position) can prevent ignition key from being released.
by Share
Add a comment
1 Answer
Most Helpful Answer
"Stuck" means three different things on these trucks, and the fix depends on which one you have — so first work out where the key is stuck, then work the matching branch below.
If the key will not turn in the ignition:
  • The steering lock is binding. This is the most common one. The steering wheel lock pin jams against the column when the wheel is turned hard against it — usually after you parked with the wheel cranked. Hold the key in the turn position and rock the steering wheel firmly left and right at the same time. The wheel will move a little, the pin will release, and the key will turn. Do not force the key itself — you will snap it off in the cylinder.
  • The key or the cylinder is worn. Try your spare key. If the spare turns fine and your everyday key does not, the everyday key is worn down and a copy cut from the spare fixes it. If neither key turns, the wafers inside the ignition cylinder are worn or jammed — a shot of graphite lock lubricant (not oil, not WD-40) in the cylinder, worked in by sliding the key in and out a few times, is worth trying before anything is replaced.
  • The shifter is not fully in Park. On an automatic, the ignition will not release the key unless the shifter is fully in Park. Push the shifter firmly into Park — sometimes it looks like it is in Park but is sitting a hair short — and press the brake pedal while you try the key. The shift interlock and the steering-column lock can both hold the key, and they can both bite at the same time.
If the key will not come OUT of the ignition:
  • Check the Park position first — same as above. On these trucks the key will not release until the shifter is fully home in Park, and a worn shift cable can leave it a fraction short.
  • If it is a manual, make sure you are not fighting the steering lock: rock the wheel while you pull the key, the same as above.
  • If the key comes halfway out and stops, a wafer in the cylinder has jammed — do not yank it. Work it gently in and out with graphite lubricant. A key that is pulled out by force can leave a wafer jammed and the cylinder will need to come out.
If the key is stuck in a door or the trunk lock:
  • That is usually a dry or corroded lock cylinder, not the key. Work the key gently back and forth — never twist hard — and put graphite lubricant in the keyway. If the key turns but the door will not open, the linkage rod inside the door has popped off its clip, and the door panel has to come off to reattach it.
  • Fitment note. A replacement ignition lock cylinder or door lock cylinder commonly fits a 1994–1997 Hilux (and the same-era US Toyota Pickup/Tacoma) — always confirm against your vehicle's exact trim and engine and the product's fitment data before buying, since the cylinder varies with the year and with manual versus automatic transmission.
Safety note: if the key snaps off in the cylinder, stop and call a locksmith — digging at a broken key with pliers pushes the broken piece deeper and turns a cheap extraction into a new cylinder. If you are not comfortable pulling the ignition cylinder or the door panel, if unsure, consult a professional mechanic.
Score 1
Add a comment
Add your answer
emmanuel ifeanyi will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 31
All Time: 31
