Up to 20% off select tools
The Craftsman Gas Snow Thrower 536.881800 is a gasoline-powered device designed to remove snow from driveways, sidewalks, and parking areas. This page provides detailed information and repair guidelines for this snow thrower that comes in different engine displacement models (148 cc, 206 cc, 305 cc, and 342 cc).
when handle is engaged
When I first go to engage the drive, it will start to move and then stop
1 Comment
@harveyharders Does the engine disengage when the snow blower stops?
by Share
Add a comment
1 Answer
Most Helpful Answer
I asked FixBot (Ai) your question with its reply in italics. Beware of Ai mistakes. I'm not 100% familiar with motorized snowblowers but if I had to try servicing one, I'd review owner's manuals and get hands dirty looking for adjustments, slippage, belt wear, etc, as a diyer. Scraped knuckles included.
"When I first go to engage the drive, it will start to move and then stop"
When a snow blower starts to move and then stops or slips when you engage the drive, it typically points to one of three common issues: a loose or worn traction drive belt, improper traction drive cable tension, or oil, grease, or wear on the rubber friction wheel and disc drive plate 1.
Here is what to check:
  • Traction Drive Cable: If the cable is stretched or out of adjustment, the drive spring may not maintain correct tension (should be 3 to 3-3/8 inches when depressed) 2.
  • Friction Wheel & Disc Plate: If grease or oil gets onto the rubber friction wheel or disc drive plate, it will grip momentarily and then slip as pressure increases. Ensure both surfaces are completely clean and free of lubricants 3. Inspect the rubber ring for wear or damage 4.
  • Traction Drive Belt: Check for wear, cracking, or looseness 5.
You can find the complete adjustment and troubleshooting procedures in the owner's manual here:
File
Craftsman 536.881800 Owners Manual
•Page 34•100 pages•5.8 MB
Score 1
Add a comment
Add your answer
Harvey Harders will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 42
All Time: 42
