How to fix a leaking radiator
How do I fix a leaking radiator
@lisabauer most of these are not really fixable by us DIY'ers. They consist of glued plastic tanks and metal cooling fins etc. Depends on where you are located you may still have local places that can fix radiators. Most commonly we, the Diy'ers, have to replace those. To remove your radiator either for repair or replacement, use the COOLING SYSTEMS chapter from the FSM. It will show you what you need to remove to get the radiator out. Not a terribly complicated job just make sure that you are working on a cold engine only. Never mess with the coolant system of a hot engine.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 23
All Time: 23
