Up to 20% off select tools
The JBL PartyBox 710 is a high-performance, corded-only Bluetooth speaker designed for large-scale entertainment, delivering a massive 800W RMS of total output power. The unit is distinguished by its extensive, customizable RGB light show and its IPX4 splashproof construction.
psu was not working.
Replace it with a new one with a ribbon cable but still no response.
Score 1
Add a comment
1 Answer
I asked FixBot your question with its reply in italics. Beware of Ai mistakes.
"psu was not working. Replace it with a new one with a ribbon cable but still no response."
This repair involves live AC mains electricity and high-voltage components, which present a risk of severe electric shock or electrocution. In many jurisdictions this requires a licensed professional. If you choose to proceed, ensure the unit is completely unplugged from the wall outlet before touching or servicing any internal parts.
Since replacing the power supply unit (PSU) and ribbon cable did not restore power, the issue likely lies further along the power path or in the control chain. Check the following areas:
  1. AC Inlet and Fuse: Verify that the AC power cord and the AC inlet board/fuse (AC Assy1) have continuity and are passing line voltage to the PSU when plugged in. A blown fuse on the AC input or power board will prevent any response.
  2. Ribbon Cable Seating: Ensure that the flexible flat cable (FFC) connecting the PSU, main board, and control panels is fully seated, properly oriented, and undamaged at both ends. A misaligned or loose ribbon cable will interrupt control signals or standby power.
  3. Main Board Failure: If the PSU is outputting correct standby and rail voltages but the main board is shorted or damaged, the unit will remain completely unresponsive. Check whether standby voltage reaches the main board.
Sources:
1 JBL Partybox 710 Service Manual - Spare Parts List
Add a comment
Add your answer
Vincent Biritati will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 29
All Time: 29
