Up to 20% off select tools
Repair guides and support for the fifth-generation Century, a series of front-wheel drive coupes and sedans manufactured by Buick.
Brake Line how to do?
I have a 1996 buick century wagon but the brakes hardlines are rusty so they have burst. I want to change all 4 but I feel like I have no clue how to start since I've only worked on newer brake hoses not full brake lines. I need help
Add a comment
1 Answer
Most Helpful Answer
@iancole86361 this is a bear of a job. Check with your local auto parts store or even your local dealer. You should get all of these break lines in a pre bend set. Something like this and it is an example only. Then the real work starts since you have to remove rusty brake lines from rusty connectors and rusty clamps. Be prepared that you may also have to change the flex hoses etc. To work on your brakes use something like this site as your repair manual.
Score 1
Add a comment
Add your answer
Ian Cole will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 21
