Washing machine does not select other functions
Washing machine does not select other functions?
Update (11/21/26)
Defy eco DTL45
Defy eco DTL45
Two things before any part gets bought. DTL45 does not come back as a printed Defy code anywhere I can find. The top-loader codes in that family are DTL145, DTL155, DTL165. Read the plate, usually on the door frame or inside the detergent drawer lid, and tell me the exact string. Parts and panels follow that number, not the shop's shorthand.
Then it depends on which kind of console yours has.
1. Power cycle, done properly. Unplug it, leave it 10 minutes, plug it back in. If it then selects, the fault is a latched state in the board, not a broken switch. Note whether it comes back for one cycle and locks again.
2. Which controls answer. Machine on, not running, press every function. If a whole vertical strip is dead, that points at the panel or the ribbon. If every button answers but the program will not move, it is the selector input.
3. Rotary knob? Unplug, pull the knob straight off, turn the shaft by hand through every position, feel the detents. Then power up in a quiet room and listen at the console while you turn it. One click per position means the switch is reporting. No click means it is not.
4. Touch or membrane panel? Look at the top edge and the seam for water or detergent creep. Top loaders splash the console and it gets under the overlay. A dead row plus a water mark under it is the panel, not the board.
5. Meter, unplugged. On a knob selector, check continuity at each position: the pair that should close and each pair that should not. On an encoder there is no fixed reading, only pulses, so use the click in step 3 instead.
6. Board connector. Pull the panel connector off the board and look at the pins: green creep, pushed-back pins, a ribbon cracked at the fold. Reseat it once and test, then stop reseating. One change at a time or you learn nothing.
7. Heat. Powered for five minutes, feel the board over the relays. A spot too hot to hold a finger on is where the fault lives, usually a driver that has let go of the selector line.
Back to me with: exact printed model, knob or buttons, which functions answer, whether it starts any cycle at all, whether you hear a click at the console when you turn the knob, and any code on the display.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 40
All Time: 40
@jeffreytem85138 What is the exact make and model of your Washing machine?
by Theo Grefalda Share
