Microphone phone not working
@rupeshkuma49405 you need to provide more info about your issue. There are 2 microphones on your phone. One is located at the bottom of the phone for making calls and another one is located at the top of the phone for speakerphone. You have to find out which one is causing problems. You can make a call and turn speakerphone on and off. If the person on the other end can only hear you when you are on speakerphone, then the problem is with the bottom microphone. You can test your phone’s microphone with the built-in loopback test by dialing *#0283# on your phone’s keypad and then selecting RCV_1stMic (bottom) and SPK_2ndMic (top) to hear the live audio playback from each microphone. Samsung may have blocked this dialer code on some of the newer One UI updates. If this test does not work, then you can open the Samsung Members app on your phone, go to Support ==> View tests ==> Mic and then record a sound for each microphone. This will tell you which microphone is not working properly.
Since iFixit does not yet have any specific guides for this phone, use something like this video to work on it. The bottom mic is part of the charging board (sub_board) (3:04min in the video) and the top mic is soldered to the top of the main board (2:31min in the video).
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 39
All Time: 39
1 Comment
@rupeshkuma49405 What have you already tried?
by Theo Grefalda Share
