Up to 20% off select tools
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Is this a problem
I’m replacing a HDMI on an Xbox one S and 2 pads look to be bridged I’ve tried to go over it with desoldering wick but it doesn’t seem to change I’m unsure if the solder mask has come away is there a way to fix this
Add a comment
1 Answer
Chosen Solution
Hi!
The last pin is definitely damaged and got seperated from the trace there.
You need to unbridge the pin first, then try to reconnect it to the trace. You can carefully scratch there to reveal the copper. Then you can connect them to together.
Hopefully that will do the job! Not gonna lie, it won’t be easy.
Please let me know how that goes!
Score 1
4 Comments:
Thanks but I’ve ended up tearing another pad off attempting to tin the pads due to a faulty iron I put too much solder on tried to wick some away and as I was doing so my iron died was only a cheap one from Amazon will look at getting a better quality one
by Share
Ah, if the damage completely killed the pads over there, a motherboard refurb or replacement is required. Hopefully the damage is not too bad. In that case you might still be able to repair it with a new soldering iron!
by Share
Thanks the damage doesn’t look too bad think it should be fixable with a new soldering iron and some wire 🤞
by Share
Alright! Fingers crossed :)! Please let me know how it goes! Thank you!
by Share
Add a comment
Add your answer
Martin Larkin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 72
All Time: 72
