Overheated wont start now
My car was overheating. A friend was driving, she said it started overheat, but she drove a little bit further. And then, when the smoke started pouring out, she stopped to be a cold. We waited until it was cool down added water, and it turns over. But that's it won't do anything else. It won't start. How do I get it running?
It was overheating because my coolant reservoir had small cracks in it like I said, she stopped the car when it started to smoke. Let it cool down when you turn it over. It just keeps turning over, but it won't start replace the reservoir coolant reservoir and put in a new throttle body position. The whole thing and sensor but still won't start
You're one of a few die hard owners of Saturns. There can be several failures to consider; fuel pump, injectors, ignition system, spark plugs, and more. One way to determine which way to go would be checking if spark occurs by removing one or all spark plugs. Several failed starting attempts should have plugs wreaking of fuel, indicating the fuel pump and injectors are operating. No smell of raw fuel is one hint. A spark test is needed; reconnect plugs to wiring but lay them on the engine with the plug bases wired to the engine block. With plugs in view, crank the engine to observe for spark on each plug. The engine will spin faster because the plugs are out. You will have performed several checks.
Zero fuel on plugs and zero spark points to the crank position sensor because the sensor generates the electronic heart beat of the ecm operating the entire EFI system. If fuel is seen/smelled but no spark, ignition system is suspect. If spark is seen but no fuel is seen/smelled on plugs, a fuel issue is suspect.
by F Dryer Share
