Up to 20% off select tools
Repair, disassembly, and troubleshooting information for Sony's slimmed-down PlayStation 5 refresh released November 2023. Dubbed the PS5 Slim, it features 1 TB standard storage and a modular disc drive.
Fan overdrive after cleaning
I did a deep clean with liquid metal change and when I reassembled the fan went into overdrive and system didn't turn on, what could that be?
1 Comment:
Hi!
So, this issue occured right after cleaning? Before that, it was all OK? If so, it does sound the liquid metal replacement didn’t go well…
Is it possible to upload some pictures regarding how it look like now?
Thank you!
by Share
Add a comment
1 Answer
Go back through the machine and make sure everything is hooked up properly. Something may be loose or disconnected. Hopefully that can fix the issue. However, if the liquid metal did leak, it likely caused physical issues/damage. Liquid metal is effective at managing temps but can fry your entire device if it leaks anywhere. Feels like shaking hands with the devil or something to have cooler temps.
If you want to give any pictures you can use THIS guide. THESE may also help you in disassembly if you're unsure.
Add a comment
Add your answer
Michael Rivera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 67
All Time: 67
