Up to 20% off select tools
Repair guides and disassembly information for the new base-model 14-inch MacBook Pro, released November 2023, refreshed with the Apple-designed M3 SoC. Successor to the 13-inch Touch Bar MacBook Pro with M2.
Display blurred and black
Apple logo and loading bar blur like when the room in dark . External display working fine . I re installed macOS and restarted multiple times . How to resolve this ? Is it backlight hardware issue ?
Add a comment
1 Answer
Chosen Solution
Did you install any new software onto your system? The graphics engine which drives the display does offer a blur function which might be active here.
If the blur changes as the image changes. It does appear the back light is working at least where we can see an image. And as you are able to see an image on the external display I think it's safe to say the display unit has failed. I've not seen this exact effect but it could have been cause by the display getting physically damaged.
Here's the guide to replace it MacBook Pro 14" Late 2023 (M3) Screen Replacement
2 Comments:
is it backlight have any fuse or something ?, in mother board ?, acutely it happened in low battery time I plug the power cable.
by Share
@eldogeorge - Are you trying to tell me the blur is a reflection? Do you have a matte cover glass on the screen?
Yes, there is a fuse. But it rarely blows unless there's a short in the logic. Did you have a liquid spill into the system? If you did that's going to need to be cleaned up.
by Share
Add a comment
Add your answer
Eldo George will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 63
All Time: 63
