Up to 20% off select tools
Part of the Lenovo LOQ budget gaming series of laptops, this one launched in July 2024.
Lap top powering off
When I plug in power cord the Laptop turns off
Add a comment
1 Answer
@chrisgonza65978, you are not giving us enough information. If it functions on battery but turns off when you plug in the AC adapter, then the AC adapter is possibly causing this. You need to confirm the adapter isn't shorting out under load and that the DC-in jack is not shorted out, etc. Let us know what you have already tried and what you have already checked, as well as if your computer works on battery power alone.
If this happens with a known-good AC adapter, then you will need to check the charging IC on the motherboard, as well as the input FETs, etc. So, we would need to see your motherboard as well as know what the complete motherboard model number is. Post some well-focused pictures of both sides of the motherboard with your question. Adding images to an existing question
To work on your computer download the Hardware Maintenance Manual Lenovo LOQ 15ARP9
Add a comment
Add your answer
Chris Gonzales will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 36
All Time: 36
